Is there an easier way to reach top dead center on #1 cylinder without removing air comp. condenser.???
Thanks Sloth:
Hi Sloth,
With AJ6/AJ16 it’s dead easy - you’ll need to remove 1st cylinder spark plug and measure it with piece of copper pipe or even stick. while moving crank with ratchet. Not sure about v12 however principles are the same.
