Not sure if this is the right place for posting this but, I need help.
97 Jaguar XJ6, Runs amazingly, well, except for the fact that it isn’t starting…So I’ve done a LOT of looking and couldn’t really find anything that solves it, but I tried a TON.
Works: Dashboard lights, maplights, seats, radio, sunroof, power locks… and not sure what else…
Doesn’t Work: headlights, highbeams, starter(as in, doesn’t crank), dome lights(with that weird center button) windshield wipers, will not shift out of park.
Theories: some sort of disconnected wire I can’t find, some sort of security “feature”, a relay or someodd item that isn’t working which I can’t seem to find.
Searched all fuses, switched around all the relays to check for an outed one. Disconnected battery for over 12 hours, ensured battery was charged, tried the security reset thing(use key to lock and unlock the doors numerous times then letting it sit in run for 5-7 minutes), tried to trick the security by rolling down windows locking doors, and opening it, then sitting in and trying to start it. I cried for a bit but I don’t think it helped the car at all.
