I am restoring my XJ6 - a 1983 model. I would like to replace the original wiring (or as much of it as possible). Does anyone know if there is anywhere that I could get the the original striped (colour coded) wiring? Or if it is even available anymore?
If you donāt mind my asking why do you want to replace most of the wiring? Thatās a huge task. Generally youād replace or repair āas neededā only.
OE wiring harnesses arenāt available anymore. The demand for XJ saloons isnāt great enough to warrant a business start up making harnesses. The wire is however, Dougās referrence is good as well as 12voltplanet.co.uk
Not to be a debbie downer, but before tearing into the wiring, have sources for all of the wiring bits youāre gonna need. junction connectors, fuse blocks, spade connectors, Poly mult-wire junction connectors for example the fuel injection connector right near the battery, and the two firewall junction connectorsā¦ Below are my thoughts on this topic.
Segway - I have a clapped out Series II that has old and crusty wiring; thatās been patched, and patched, then patched again (not by me). Like you, my thoughts are OK, this is a rats nest, and needs to be sorted. How I go about it, is remove it all, then put it all back one loom at a time. well then I started to think the process through.
Wire coloring
The wire colors arenāt a big issue, it all depends on how deep your pockets, you can have the wires as well as the harnesses made; My pockets arenāt that deep. I was able to acquire the right colored wire (one color at a time). As i started to formulate a game plan, I soon became flummoxed, by the other electrical bits I DIDNāT have. such as poly multi-wire connections, the countless connectors under the console, and in the boot. The original white burrito looking crimp connectors are still available, but why? these connectors are the plague to Jaguar electrics especially in damp or salty climates (in which both are true where I live).
So if Iām not going to use the crap OE connectors; then why did I track down the original wire coloring - just document what new color wire is replaced the old color wire. Right!? To this day, I still donāt know. I havenāt started down this rabbit hole yet. Iām still sourcing cheap alternatives. besides I have bigger fish to fry - blown head gasket.
Agree. Our Series 1 has original āRistsā loom, any wiring insulation that became heat embrittled was replaced using similar colours (as much as possible) provided by my friendly jaguar wrecker from his stripped car stocks. All for cents per metre. Paul
Without the correct wire colours, Mark; the original wiring diagrams are useless - which will present a problem when searching for electric clues, and helpā¦
Certainly, any colour will do to carry current to where it is needed - and amending the wiring diagram accordingly will work a treat. And future owners will bless youā¦
You are correct (as usual) Frank, I understand the brevity of maintaining the originality. If you recall, I lived that nightmare with the Series II and the ignition / distributor that you helped me with. Thatās why I said document the color change keep it in the car, keep it on file, keep it in the computer, tattoo it on my forehead just donāt lose it.
I guess I was thinking out loud, I know why, and it was a stupid post. Sorry.
Having been elbow deep in some old Jags and dismantled a Series III Iāve found that A) 95% of the factory installed wiring is in pristine condition and B) it is not easy to remove and reinstall!
Wiring exposed to engine bay heat and/or exposed to weather can take a beatingā¦and often needs repair. Not difficult, generally.
Over the years Iāve heard people mention āā¦rewire the whole carā¦ā leaving me to wonder whatās going on. Unless the car has been in a fire or flood such a major undertaking shouldnāt be necessary
Scott,
You didnāt indicate where in the world you live. Just in case you live
in the USA (or reasonably close by) there are two sources that might be
able to help you. The first is British Wiring in Bally, PA and the other
is Rhode Island Wiring in Kingstown, Rhode Island. I have used both for
wiring needs for my six Jaguars, however I did not purchase individual
wires to rebuild the harnesses myself. Check out their websites and
perhaps send them a request to see if they can help you. If you like
elsewhere like the UK, or Australia you might have sources closer to you
that might help.
Second that, Doug - he did the right thing anywayā¦
As an aside; your point about wholesale wire harness replacement unless really necessary is very well taken. The companies providing replacement harnesses usually also makes part harnesses for vulnerable areas. And in any case, if they donāt; ordering the lot and use the pertinent parts is viable - and saves a lot of unnecessary workā¦
I have made some harnesses (out of neccesity only) and here is one way I did it when the correct colored wire is NLA or expensive.
Using the original (or preferably a āwreckā harness, dismantle it. Retain all connectors.
Snip out good well-colored sections of wire that have been protected.
solder about 2-3ft of ācorrectā color wire, connector to āregular colorsā wireā¦they will be hidden in the wrapping.
what you end up with is wrapped harnesses with correct colored wires and fittings showing, and the regular wire is not visible (still do document what you did)
would only do this if I had to though, would not like to try on a FI XJ
