I see the sender in my BW66: does it go straight to the speedo, or is it not that simple?
Straight, I think. There should be another wire for the CC, let me have a look
Actually too late to have a look, but:
That tells me they’ll hook up straight. I wonder where my wiring diagram is. Can’t find it.
Thanks! That should make if somewhat easy.
Ill have to calibrate it, somehow.
Ugh, good luck! The transducer creates pulses. 12v? Pretty much all I know. Either an interface unit, or try inside the speedo… better not?
What’s your gearing ratio?
Final drive is 3.73, and tire diameter is TBD.
