I’ve been head down bum up for a while now and haven’t updated the list with progress.
Inlet flow development stalled when I needed to start simulating the valve timing and combustion event. I needed to be confident in my piston design.
However, I have been trying to see if I can use the Chev LS7 titanium con rods in my engine.
These are very nice rods, very well designed and are available cheap. For some reason, the fad in the US is to take a brand new motor, rip out the titanium rods and put in forged steel (because they are “stronger”) and then (I assume) supercharge the motor to increase output. The result is that there is a market for unwanted titanium rods. No one wants them because they are considered “weak”. That may be the case for an 800hp V8, but it is not the case for an 800hp V12.
My crank is already machined for the 2.1" big ends to make use of forged Chev rods. However, the LS7 rods are wider and require more journal length (or need to be machined down and then plasma coated again - ouch)
So … I have a fully counter-weighted crankshaft design developed to make use of the LS7 titanium rods.
Simulations are showing substantially reduced centre bearing stress with a fully counter-weighted design. Even with the full counter weights, the total crank weight is lower than standard and inertia is reduced substantially.
However, I have a couple of issues that I am still working though.
- The bank offset is 0.75". 19,05mm. The LS7 rods are 24mm wide. Thus the con rod offset (bank to bank) is 24mm. Because the bore offset (bank to bank) is 19mm there is 5mm mismatch or 2.5mm of “off centre” happening at the small end of each piston pin. Doesn’t sound like much, but is scary to look at and feels wrong. From what I can see, the factory standard engine has an offset also. (Rods are 0.84" wide (21.34mm) meaning there is an offset of 0.09" or 2.3mm). In fact, I think one banks rods are dead centre in the pin, and the other bank is offset by the full 2.3mm. (But I could be wrong there)
But the crunch is that I need to be very very careful with my block measurements and crank design to make sure that when fitted up (and thrust washers in place) that the con rods are in an acceptable position and there is clearance at the piston pin. And I need to run some calcs to see what impact the little end offset will have.
- Total deck height on my block is marginal. The block has been skimmed too many times. And I am trying to see if I can get away with very high lift valves (15mm - 16mm). I am hoping to maintain at least 78mm stroke. This requires big valve pockets in the pistons which has a negative impact on compression ratio. So I am juggling a few things to see how it pans out.
Once I have a piston crown design that I think will work, I want to try to see if I can simulate the compression stroke to predict swirl and tumble, and see if there aren’t some small details that can be added to promote that. Even through there are large valve pockets, I am trying to encourage the mixture into a bowl around the spark plug.
None of this costs me anything but time. But if it does all come together and make sense, then I need to take a deep breath and see if I commit cash to see if it all works.
