I am overhauling my ENV axle and would appreciate information on the torque settings for the crown wheel bolts, bearing caps bolts and differential case bolts. All these bolts are secured by locktabs, From a previous conversation I believe the pinion nut is sufficiently tightened to secure the companion flange to pinion and not torqued with the preload adjusted by the addition or deletion of the pinion shims.
Thanks
