Excess crankcase pressure....Help
I’m a new member looking for help. I Love my 97 XK8, but I have spent far more hours working on it than actually driving it. The newest problem is that within 100 miles of replacing the timing chain guides it BLEW the rear main seal out. It dumped all 7 quarts in 1 mile. The oil is not dripping out, it is blasting out. This seems like excessive crankcase pressure. Is it possible that I connected something incorrectly, or could something have plugged up?
Help. Any advice appreciated, my wife wants this car back on the road soon.
Not sure exact configuration of your car, but generally there is a PCV (positive crankcase ventilation) valve, that is routed with hoses, between the intake air filter and the engine block, for the purpose of relieving the pressure caused from the underside of the pistons - when this PCV path is blocked your symptoms appear- check your PCV valve for it may be in need of replacement.
The left cam cover has a PART LOAD BREATHER and the right cam cover has the FULL LOAD BREATHER.
There is a TSB (600-03 amended) for the procedure to check and clean the part load breather orifice.
600-03am3 Part-Load Engine Breather.pdf (114.2 KB)
That was my first thought as well. I could not find one, and while researching it I saw on another forum that 97 XK8’s do not have a PVC valve, but thank you for responding.
motorcarman, thank you, that sounds easy enough to do, I will try it.
Looks like what motorcarman posted (thanks) takes the place of the old PCV valve system to help with crankcase pressure - if you can, post an update of your results after following TSB.
It is an 97 … do a compression test
Is it the original motor?
If so and how many miles?
Lovely early car but they go …
B. O. O. M. Very fast from one of two things
100,000 mile limit or nickelsiil engine!
Do a compression test but the key is how many miles if your near 100,000 that’s about it my friend
Gtjoey1314
Ps the guys are right with the tsb but…
Hi all newby here, interested to hear of the 100,000 mile life or failure of nikeseal bores on these engines, I have a 2000 xkr on 130,000 + and 1998 xk8 on 110,000 miles and they are both running sweet as a nut, where did you get this information from.
rrosscoe
Well you are one lucky camper…
Change the tensioners and chains , clean out the blow pipe and refresh the transmission every 30,000 and you will be happy.
Overall by 2000 alot of issues were resolved.
If you bought the cars new and had it all this time , Congrats.
If not , you might have a replacement engine along the way.
Very common, 97,98 were the worst of the bunch but , it rolls across to 2000, beyond 2000 with tensioners and chains, steel sleeves came around the 2000 model year or so.
GTJOEY1314
The 100,000 mile fable is ‘just-that’, a fable.
The failures were mostly due to high sulfur fuel and many manufacturers suffered the same fate.
BMW engines in the 1990s were commonly failing also from the nikasil liners.
The only other thing that will absolutely destroy the engine it OVERTEMP.
The aluminum pistons swell and scrapes the lining away FAST.
The Nickel Silicon lining is actually harder and more durable that a steel or cast iron liner.
I have a few customers with over 250,000 miles on the pre-August 13, 2001 engines.
The high sulfur fuel is a thing of the past due to EPA regulations so no worry about that.
Keep oil and coolant in the engine and it should last a LONG TIME.
Hempstead Jaguar was replacing 2 a week
It was a BIG warranty problem
That’s why a 1998 xj8 or close xk8 goes for peanuts if they are high mileage
Gtjoey2314
Both original engines and both had timing chain tentioners done, oil and filter done on XKR just need to do it on 8, only real problem is the tin worm the XKR rear quarters are due repair due to the fact that when i got it,(10 years or so) i took a look at the inside of the rear wings in that area and found that the air flaps had allowed all sorts of dirt/sand to deposit itself in the bottom of the rear wings to a depth of 3 inches, this is what started the rot but managed to keep under control until now, sorry for diverging
rrosscoe
Great ownership!.
I loved my 2001 XK8 convertable, Silver /black/black top.
Geoff Lawson was a friend, he did a great job on that car…
That was a wonderful period and last of the FAMILY feel at Jaguar.
Enjoy that ride!
GTJOEY1314
