Can the exhaust manifolds from a MK4 3.5l be used on a MK5 3.5 l engine?
Hi Ronald, Yes they are perfectly compatible! Cheers Darryl
If you are buying from an unknown source, be aware the 2.5 and 3.5 manifolds look very similar but are not the same.
Here is a 3.5, parts C484 & C485
Here is a 2.5, parts C659 & C660
Thanks Rob,
I understand that there is a difference between 2.5 and 3.5 manifolds, but is there a difference between Mk4 and MK5 manifolds?
They are the same part numbers, so apparently no difference.
