Has anyone ever cut off the shield that surrounds the exhaust pipe (number 12 on the picture) ?
It appears to be fastened onto the pipe by a pinch at either end and Im getting a bit of a rattle in that area. Im curious if it’s actually connected to the pipe anywhere else along it’s length.
Grooveman, Can you put the auto on a lift,or on ramps, and get underneath to get at the shield? If so, and with exhaust cold, shake the shield around to see it rattles. If it does, perhaps several hard yanks on the shield will give some deflection and clearance from the pipe. Which way to yank is the ? Trial and error. Suggest not cut off the shield. SD
A ball pein hammer can ‘dimple’ the shield in strategic places to eliminate the rattle.
Sometimes you can jam washers or metal shims into ‘loose’ areas.
How about stuffing some asbestos (yikes!) or better still, fibreglass cloth in between the shield and the muffler? If you poke enough in there using an old screwdriver or something, that would end the rattle, wouldn’t it?
