Hello Frank,
Your picture tell a thousand talesā¦ Clearly you have a mixture problem on RR, LF and LR carburetors. Additionally, is the dark material just soot or is it oily also?
First, lets go down a quick list so weāre on the same page.
Do you own the Official Jaguar Repair Operations Manual (ROM). Itās a very good start point. The manual gives a pretty good account how to synchronize the carburetors. That must be done first.
Second: Do you own an air flow gauge - UniSyn or similar? The method of sticking a hose in the carb intake, listening for the hiss and matching all 4 is C R A P!! Use a Unisyn or similar tool.
Third: Do you own a fuel meter needle adjuster tool. S3 Strombers, the mixture is fine tuned via this tool. Tool runs around $10 USD.
The adjustment tool really needs to be used in conjunction with an Air/Fuel mixture analyzer. Those āColor Tuneā devices worked OK in the 50ās/60ās but you need something more refined.
Lastly: Have your Bypass Valves been attended to, replaced or blanked off? If you arenāt required to pass an emissions test blanking them off and plugging the vacuum line (hose) will save you a lot of headaches (vacuum leaking) IMHO.
Read up all the articles you can find on the Internet regarding tuning (mixture, etc.) of Strombergs. They arenāt as difficult as most think. They do require periodic attention and maintenance but they work well when properly functioning IMHO. If carb oil level(s) are constantly low then the o-ring(s) probably have become brittle and need replacing.
Your posted spark plug photos clearly suggest three (3) carburetors are supplying an overly rich mixture to the engine. With the proper tool and sampling meter that can be corrected easily.
Are the carbs original (factory - never been worked on) or have they, at some point in time, been rebuilt? Rebuilt and Overhauled are not the same! If youāre running Ethanol laced fuel then the floats must be the newer āEthanol Resistantā type, otherwise they will suffer the effects of this blended fuel.
Lastly, a little more car info would be helpful to the group. Update your member info will help that.
Soon More Happy Trails,
Dick
P.S. A correct mixture and properly tuned motor, the spark plugs should last 50,000 miles or more. Re-gaping the plug my be required at some point also.
