You likely all know this here but posting for those who may search in need later. This check engine code relates to the EGR valve. I took mine off, cleaned it with throttle body intake cleaner cleaner and put it back on once verifying it still
appeared to work. Easy job. Two bolts and a hose pull. The code will not clear (yet) after 20 minutes of driving thinking of a new one as well as a solenoid replacement could but both easy jobs. Here are the pictures and a video of it uploads.
All - this is sincerely appreciated. Just what I needed but could not seem to find. Will ease into this fix and post as I venture in so those who are like me can find their ways and those like all of you can reminisce about “all those crazy (not so) scary warning lights and fixes.” Will have to head to support and make a donation in all your names.
Update: got the new valve. Installed it. Disconnected and reconnected battery and? Code is cleared! I actually think the old one is good, but want to slowly replace all the old stuff anyway so really happy here. Appreciate all the help. An aside: Keeping the old part to see if it can’t be restored or of use somehow down the line. Biggest learning experience for this one? Parts are hard to find and not cheap.
Timeisrelative
(Jason Miller 1993 XJS 4.0 convertible, 1997 XK8 coupe )
10
Yeah it really was surprising to me when I first got my jags, just how little aftermarket support, and even Jaguar support there is for “older” models. Smh
Will do - agreed, same here but it’s holding up. Today’s “repeat offender” issue is the right passenger side window panel. Works, then randomly sticks up, works, then randomly sticks down. Not for off topic discussion here but I spotted a small “fray” in a wire so hoping for a small “splice and black tape” miracle before I “escalate” it.
