I will try and upload some pages from his book on the process via pics.
Its an eye-opener
I agree its not stepped, but he uses thin strips of abrasive and the marked card to make the alterations
Its an eye-opener
My 120 has 2 HD8’s. It had UO’s, but when I took it to the rolling road they filed the needles and got more power and torque. They recommended to me UN’s as a test, which they did not have in stock to try. Did not seem any difference, so assume they are also about right on my car. I had a set of spare UM’s which are the standard needles on the HD8 on an E type. Tried them - totally useless as would not rev above 3000. Also had spare UE’s again above 4000 flat.
The other thing, is it depends where jet is set, how high or low within reason.
Nobody has mentioned the graphical needle chart by the strangely named - Mintylamb.co.uk/suneedle it is very good for visualising the needle profiles from the SU needle chart booklet.
Indeed, but that adjustment is supposed to be used exclusively for idle mixture. But as you say, many folks wind up lowering the jet to a proper mixture at speed, even though that makes the idle mixture too rich.
Also seen people doing the opposite and put the needle slightly higher up in the piston, rather than setting the needle groove or shoulder to the bottom of the piston.
These tricks don’t actually work. The taper of the needle determines the fueling curve. If you have the wrong needle, you can manipulate the jet to get the correct mixture at one specific load level.But at higher or lower loads, it will still be wrong. I did quite a bit of experimenting with my dual A/F gauge, and found that it wasn’t possible to get a satisfactory fueling profile without swapping needles.
You can always seet the needle farther up in the piston to get a richer profile at idel. The OU needle seems to be the best i have tested so far. A little stinky at low end and gas milage goes up. But it will rev out to advertised rpm. Fialing seems kind of chunky could you not sand them a little where you want. A little goes a long way.
Great stuff james. The car looks really cool. You should remind us all with a ‘before and after’ photo(s)
