The reason I started this as a separate thread is to consider the specific issues of fitting Ford EDIS/Megajolt to 4.2 fitted with PS and A/C.
Rays beautifully engineered kit parts are made for E-types, and the bracket parts not entirely suitable for other models, as he mentioned, so rather than discuss in the E-type forum, I thought it better to start a topic, with various pics, links and questions
The main issue that I can see is that the “best” place to mount the trigger wheel is on the 5" outside pulley, using a 5.125"trigger wheel.
This means the VR sensor bracket will have to be located 4" (100mm) forward of the block
The issue is whether runout in all planes can be maintained to within ~.020".
here is pictures showing the mounting style and position of the VR bracket I would use (example is E-type, pulley is non-standard billet)
and the layout of pulleys on my A/C 4.2…just to clarify, I want to mount the trigger wheel on the front pulley, placing it on the damper would need machining
another lister (Nick J I think) has done conversion on an XJ
here is some pics, (but they cannot all be expanded)
more later…
this picture shows the options
a) in front of 5 " pulley
b) in front of damper requires machining 3-5mm of front of 9" damper
c) rear of damper ( I think this where Ray mounts his)…requires +5mm of machining from rear of damper
it is my understanding the shorter the VR the bracket, the better, in terms of accuracy, in respect of engine vibration
