Flasher relay on 150
Where is the flasher relay on a 150 roadster? tks.
Should be on or near the firewall, by the fuse box:
I believe that’s the flasher, but no power to it. There should be a flasher relay also with multiple terminals on it. Tks for your reply
You mean this thing.
IMG_20210103_130359304
The relay Bob refers to mounts on the side of the engine bay along with the overdrive relay, under a metal cover:
great. that’s what I’ve been looking for. no wonder I couldn’t find it. tks so much
rjb
Later 150 did not have the DB10 unit they just had the small can flasher unit…so check the chassis number against the info Rob posted above…Steve
will do. thanks so much.
