Flasher replacement
Hi All,
My Flasher has the interior arrow flash only once but the exterior lights flash appropriately.
I think I need a new flasher. Is there a better flasher for me to purchase?
Thank you!
Shelley Yoelin
61 Mk 2
69 E Type FHC
Are you running LED bulbs? If so get an electronic flasher. Otherwise your old flasher may be tired a new easy to obtain one might fix your problem. Switch out the one from your other Jaguar and see what happens.
If the flasher unit replacement fails, you may need to clean the contacts on the flasher switch.
The indicator lights have separate contacts that carry ground instead of power.
