Hello All. I’ve replaced the flexible clutch hose on my XK150. One end is fixed to a bracket on the chassis. the other end is fixed to a bracket on the engine block. My old hose was fitted to the chassis bracket. the other end was fitted to a bracket (looks home made ) but was not fitted to the block, just hanging loose. I wondered if anyone would have a photo of the bracket and the location of the bracket.
Phil The flex hose is supported by a bracket on the chassis, the other end is supported by a metal bracket which is bolted to the front side of the rear engine mount with two small bolts, as the metal pipe goes over the bell housing it is secured with a clip to the TOP bolt on the housing, it then passes the starter motor housing and secures to the slave cyl,
