Hello all,
occasionally I feel a set of foglights might serve me and this week I got my hands on some period Hella fog lights at a very reasonable price. I also found the dead wires to be used for the fog lights and wanted to fit the fog lights, ideally using the original light switch. From this forum I learned that on SIII cars the light switch can be manipulated such as to be depressed and operate fog lights in the last position. Some kind of locking ring needs to be removed to enable the push/pull movement.
Now I have two questions: The first relates to the origin of my car, as I know that in the 1970s it was common in the UK to actually have a combination of one fog light and one driving light. Talking in terms of the Lucas Square 8 used originally they came as LR8 for the driving light and FT8 for the foglight. Occasionally, you even find that mix today
Just how were these things switched? Were you running on 3 resp. 5 lights, with the foglight combined with outer lights or even side lights and the driving light combined with the main beams and all four main lights? Powering both in fog would sort of defeat the purpose of the foglight. In any case I’d like to wire them up “modern” style, i.e. operating (both!) only with low beam and going out with high beam. What do I have to expect when I kind of restore the factory setup?The second question relates to the light switch itself. While the parts book describes quite clearly the Lucas Square 8 fog and spot lamps as optional extras (2L 05L), it doesn’t mention a particular light switch for fog lights. Instead two types of switches are indicated (1I 03L): C.38628 for early cars and C.46318 (C.46315) for later cars. As per the car number I’m supposed to have the early type. Could anyone please be so kind as to check the part no. for the SIII switch? In any case I’d be happy about any information on the activation of the fog lights. There should be either a special switch or an “upgrade” mode for the normal switch, shouldn’t it?
Thank you all in advance and enjoy the week end
Jochen
75 XJ6L 4.2 auto (UK spec): .
