Good evening all,
it has been quite some time that I went into that fog light project … some other things came in the way, but now I’ve returned to the issue …
I decided to run the fog lights through a relay, mostly because the wiring scheme suggests that the low beam head lights are turned off, once the fog lights are operated, and this proved true when I tested the fog light position: power was on the red/yellow wire while the low beam lights went out.
So I used the pre-installed red/yellow wire (for the fog lights) as a triggering wire which I put on pin 86 of the relay and grounded pin 85.
For the operating circuit I stole power from the brown wire at pin 81a at the headlight relay (# 231 in the wiring pattern; it is always powered and not controlled by the headlight switch (# 6 in the wiring pattern) and connected it to pin 30 at the relay. Pin 87 at the relay supplies the fog lamps.
To keep the low beam head lights operating with the fog lights on I connected pin 87 at the fog light relay to pin 56b at the high beam relay.
… at least that was my plan. BTW, this kind of operation is pretty much what US buyers got if they purchased Bosch fog lamps for Jaguar XJ-S HE and XJ SIII cars - thanks Mark for the instructions; I’ll post a write-up as soon as I’ve got a functioning system.
What happens though is that the fog lamps come on directly when I put the light switch to “head”. In contrast, they shut off when I put the light switch to “fog”. The high beams operate and - even better - then the fog lamps shut off automatically.
So, my first idea would be I got the connection to the high beam relay supplying the fog light operating circuit right: obviously, the fog lights come on - so they’ve got to get power - and they go out when high beam is on and pin 81a at the high beam switch is no longer powered.
However, I must have messed up the reverse connection: instead of powering the trigger at the high beam relay while the fog lights are on and the regular power supply is dead, I have connected the operating circuit of the headlights (pin 56b at the high beam relay) with the operating circuit of the fog light relay … aargh. Basically, I have spliced in an extra set of low beams
So, I need to reshuffle the wires: in fact I want the trigger at the fog light relay (pin 86) to also supply the low beam head light (pin 56 at the high beam relay) at times when it is not powered due to the light switch in position “Fog”. Please, tell me I’m right … well, probably Frank has already told me to do it like that one year ago, but I didn’t understand …
Thanks again
Jochen
75 XJ6L 4.2 auto (UK spec)
