For the life of me I can't get the rear doors to unlock
I have no fob to unlock anything, so that’s out. I keep twisting the key in the lock and the rear doors will not unlock. (The locks work, so this isn’t the problem).
Isn’t there an un luck button on the dash or when you pull the drivers door pull they all unlock?
Is the child safety switch on the door jab on?
The only thing I see on the dash is a button that locks the doors. (I tried that). I’ll check the door tomorrow.
Thanks.
Well, the right rear door will neither lock, nor unlock unless it is performed manually.
If you have done the rest it’s the relay switch
Good luck my friend
Gtjoey1314
Where is that relay switch?
There should be a right side box near the kick panel and a plunger switch in the door…
Try the door first.
gtjoey1314
