I have a 1994 XJS straight six in the shop now with peculiar brake issues. It all started with lights on the dash, typical old accumulator issue. Replaced accumulator and all was well… sort of.
No ABS or Brake light on the dash. Old fluid was completely flushed out and bled. Rear brakes were bled per service manual by turning on the ignition and using the brake pump to pressurize the fluid.
On a test drive, the brake pedal is firm, stopping power is great. However, approximately every 10 applications of the brake pedal, the pedal sinks to the floor, and the car is jerked from side to side as you first feel the passenger front caliper engage, and subsequently the driver front a moment later.
I spoke with a gentleman in Connecticut that owns a Jag Specialty Shop and based upon this, he recommended replacement of the master cylinder to repair the problem. He said he had seen this exact issue ONCE before.
So onto the master cylinder replacement. First replacement was a dud. So had to install a second “remanufactured” master cylinder.
Bled out perfectly, again with the procedure stated in the service manual, also bleeding the brake pump itself.
Everything seemed wonderful, no lights, firm pedal, brake pump would only engage when needed.
Go for a spin, exact same issue. Sinking to the floor about every 10 applications of the pedal.
Coventry West wants us to install another master cylinder… I do not believe the master to be the issue. We have also replaced the proportioning valve as PM but nothing changed.
The only other thing I can think of is the brake pump itself… If it is weak, every 10 or so applications, there is not enough pressure in the system. Therefore the sinking to the floor and delayed application of the front calipers.
Another note, after normal driving the front brakes will be around 250-280 degrees F and the rears at about 150.
As it seems, the rears are not doing as much work. When the car is on a lift and the pedal applied, all 4 wheels are locked and cannot be moved.
Any insight is much appreciated.
