Never Mind. Mechanic error (me). The bearings were not fully seated. I reseated them on my arbor press and can now shim them.
I am assembling the front suspension on my '65 now. The front right rotor is not centered on the caliper. Inside clearance is ~.200" and the outside clearance is ~.060". (Adding shims moves the caliper inboard and will make the problem worse.) With pistons retracted nothing is dragging. In my bag of parts for that assembly I don’t have any shims so I don’t think there were any there originally.
Any suggestions on what I should do? Leave it alone since it is not dragging? I am thinking this is my best option now. If is is a problem when I get the car together I will deal with it then as is is not that hard to take apart.
I have a mill and could take some off the caliper to get it more central? Any other suggestions?
The other side took .010" in shims, top and bottom, to get it centered.
thanks,
Dave Christensen
'65 OTS - in pieces
