Front damper , inner wing support mount 1990 xjs
Hi, My XJS has a lot of rust around the support structure of the front dampers. It looks like the support is welded into the inner wing, rather than bolted on. I will need welding also on the inner wing itself. My question, can you purchase the supports separate, and have it welded / fixed , or is it all one part?? I cannot seem to find any information or images online, any help, greatly appreciated. The attached photo, should explain a thousand words.Thanks.
Don’t know if you can find a replacement but it’s clearly too parts.
If you have access you can fix the inner wing from the other side, otherwise you will have to remove the support.
Thank you Aristides for your prompt reply, I guess I will have to do as you say
