Hi All
I read somewhere that there are tapped holes in the front bumper for the front fog lights
I have looked a few times and cannot see them on my bumper, nor any markings in the rubber to suggest they are underneath.
Can anyone tell me how to find them. I found the cables and fitted the cover part of the switch and 12v is there ready to go.
I have noticed in cold weather the car starts fine but then the revs hunt from 900 to 300 and sometimes it stalls. It needs a minute or two with a gentle rev before it goes back to normal. I am thinking its might be a dirty throttle body - but before i look wanted to ask for thoughts. One other thing is when it is hot it doesnt start up straight away but turns over and over. Ive check the fuel pump and none return valve and all is fine - turning key on and off to prime the line makes no difference. I just swapped out the crank shaft sensor - as i was told that could be the problem but not noticeable change. wondering if they are related and to do with the intake air temp sensor?
Any help and insights would be appreciated
Thanks
Ian
