Front shocks for the Mk10
(peder) #1
I recently changed to GAZ, and put them on 10 clicks, of 25 max.
I find them very hard on the springs, causing metal to metal noise on uneven road surfaces.
I had
Koni many years ago and they were very hard as well.
I want a firm ride but no noise from the springs…
(Robin O'Connor) #2
I would try backing off to the softest setting to see if that improves anything.
(tony) #3
I apologise for the very blurred photo of a document which shows a list of front shocks compatible with Jaguar 420G/MKX
I only found out AFTER i fitted the ones that are specific to Jaguar
note that inclusions are Isuzu Trooper, Mazda BT50, Ford Ranger…all modern 4wd with a range of adjustable shocks
Also MANY common vans such as Toyota Hiace
(peder) #4
Thank you Robin.
I went down from 10 clicks to 5 and they are now fine😊
(Robin O'Connor) #5
Good to hear, thanks for reporting back.
