69 Coupe.
Good day to all. Things going pretty well on my re-assembly of my 69 FHC.
The car rear wheels are sitting about 16" off the ground on home made wooden stands. No front wheel on at this time. All suspension and drive train in; along with wiring, starter, brakes and torsion bars are set at proper setting etc etc. While waiting for some parts, I messed with the front sway bar today. The right front sway bar end is “slightly lower than the left”. Maybe 3/8". As I said, all suspension is in and “hanging” but upper ball joints are in and loosely tightened. The sway bar is properly attached with all hardware, spacers, brake line holder, etc.
My problem is in order to attach the link to the sway bar end, I have to pull forward (to front of car) very hard on the link to barely get the bolt in and the ends don’t really line up properly. Also, the lower link bushing is torqued upwards since the link is not vertical; but pulled forward.
The question is… When tires are on the car and it is on the ground with the torsion bar loaded, is it likely that the links will fit better or is there something amiss?? I don’t have 2 more wheels right now and any attempt to jack from beneath the lower ball joint obviously lifts the front end off the jack stands!!
All the pictures I have seen appear to show the link and sway bar meeting reasonably perpendicular.
All parts, suspension, sway bar etc are original to the car. *All new bushings in everything
Mark
Murrieta, Ca.
