What have people used for the sponge seal that fits in the channel around the edges of the under-wing splash panels on a 140DHC?
Viart lists these as BD.10704/3 and BD.9317/4, not found on any parts supplier. Anything that’s ¼" x 1⅜" section? Possibly closed-cell neoprene rather than sponge, I guess. Anyone know a UK source?
I’m wondering if this might be better. I need to ‘push out’ the upper section of the wing, just gently, and I think this might support it better than just sheet sponge, which seems to be what Jag used.
https://www.woolies-trim.co.uk/product/1803/rubber-extrusion
Steele Rubber has more profiles than you can imagine. I’d look there and adapt.
Thanks Mitchell, I’ve used Steele several times for special bump rubbers etc. for Cobras - but Woolies will cost me a lot less for generic seals like this as they’re here in the UK.
If you are not concerned with originality a sponge rubber garage door seal can easily be cut to fit what ever variances you have.
Baines comes closest, I would guess, but I am not a XK140 expert
or
Tadek
