Fuel consumption, CO
(Paul Wigton) #41
Just about a sure sign the carbs are running too rich.
(Frank Andersen) #42
Champion is my favourite, Nick…:slight_smile:
But you will not notice much change in fuel consumption if the carbs are the culprits…
Frank
xj6 85 Sov Europe (UK/NZ)
(nickhill) #43
Hello everyone,
Back from the garage following ignition timing and carb overhaul.
Immediate result is no more smelly exhaust and fuel consumption now about 20mpg at 50-70 mph. Which feels more like what it should be.
Thanks for your help.
Nick Hill
XJC 4.2 (1975) Canadian spec
Paris
(Frank Andersen) #44
That’s about as good as it gets, Nick - unless you are a fanatic…:slight_smile:
Frank
(nickhill) #45
Forgot to mention the entertaining CO stats:
Legal limit in France: 4.5%
Before carb overhaul: 8.86% (!!)
After carb overhaul: 1.36%
(Jochen Glöckner) #46
Nick,
1.36 % CO seems a bit too lean for my taste - I’d rather aim for 3 % and you even stand a chance that your mileage increases further because the richer tuning gives more low-down torque and reduces revs.
I envy you for the loss of the smelly exhaust!
Best wishes
Jochen
75 XJ6L 4.2 auto (UK spec)
(Frank Andersen) #47
I agree with Jochen, Nick - carbs are set fat to ensure consistent performance through load and rev range.
Principally; lean running requires more pedal for the same output - not necessarily good for mileage. But if your engine behaves, no harm done…
Frank
