My 61 MK2 3.8 has a horrible plastic fuel filter which I want to replace with the original bowl filter. I have found a complete filter unit in good nick but can’t find the mounting bracket C14726 via any of the usuals. Can I just fashion something in mild steel? I assume it does nothing other than hold the filter unit off the valence and possibly insulate it or stop it rattling.
Any comments.
Not sure if this helps, Ian, but these are pictures of the one on my S type. The SPCat notes the p/n as C23115. It would be easy to replicate this from some 1mm m/stl.
This one is angled at about 45° and with a crank to offset it from the inner mudguard to provide a clearance for the filter holding nuts. I don’t know if this is compatible with your car. If you would like a dimensioned sketch, I can do that.
