Is this the stuff Wigs?
Rick
Rick
That is the stuff I used.
Mike
I recently installed the bulk hose obtained from Moss. It will seal just fine, but…it did not look right with too large an OD and a bend radius that was about a foot. I had purchased some 1/4" ID off white nylon hose offered as replacement hose (about 10 ft) a few years ago but it did not look right at first - well, that was until I compared it to the original hose and it is a much better match. So I removed the larger Moss hose and used the smaller hose. Fittings went on fine with a heat gun to the fittings and no leaks. Bend radius is about 3-4 inches, and it fits better.
Not sure where to source the 1/4" off white nylon hose now.
Looks correct from my house!
I’ve used the moss stuff…. No leaks original fittings ….just needed a bit of heat to turn the corners
