My 95 VDP 4.0 6cyl won’t start after a 6mos. storage,battery cables pulled during storage., it ran great before. Can storage ruin the in-tank pump to the extent of “nothing”? I think it’s the fuel pump because no fuel pump noise, no fuel @ the rail inlet, tested the relay & getting 12v @ the green plug via key on & jumper wire. I wanted to check the inertia switch but don’t know if its on the US pass side foot well. I see two rubber covered “somethings”. Are either the inertia switch ?
I’m trying to eliminate all the easy stuff before going after the pump.
