Yes…
They are the same pumps used by Lincoln, jag, Aston and others under the premier group at the time.
When they sit in fuel and don’t get used they crumble internally
When they start to crumble and run low they pull more and more energy
Between the breakdown rubber seals, restricted flow and draw they heat up and burn out
Db9 , we’re the worst , every two years…
It’s the above combo that does them in
The Aston label costs 3 grand
The Jag label 600
Pep boys has the Bosh pumps for 86 dollars
Your choice …
They are all the same pump
Good luck
Gtjoey1314
