I’m sure Pirk wouldn’t mind mailing you out a bit if you needed it…
I ordered both, but the firm was the right choice. Am happy to mail a bit of tube if needed. Lemme double check the measurements of what I have…
Ok heres what I got High-Temperature Viton® Fluoroelastomer Opaque Tubing, for Chemicals, Firm, 8 mm ID, 10 mm OD
10mm OD? You sure?
Pirk,
Sounds a little too small? Should be 1/2 OD and 3/8/ ID. I’ve tried 12mm OD 8mm Id and it was kinda not quite right… Are we talking about the same thing? Or maybe you’re labout the viton seal that goes inside of the hose fitting nut? (Small bore):
I measured almost 13mm OD on the OEM part I have…
Yup - definitely talking different things… same type of thing, but different model and fuel line. When I did the fuel lines into the tank, I had to get Viton tubing for the seals or double up on o-rings.
In any case, you can get 3/8" ID x 1/2" OD (McMaster-Carr)
The tank one is 1/2 od 3/8th id.
The one from fuel rail hose to hard line os 12x8mm (aj6 engine)
