Can someone share what the normal fuel pressure is for an 84 XJS?
Jeff
Jeff
28-30 psi at idle (17" vacuum); 36 psi with no vacuum on “B” regulator.
thank you Robert!!
Jeff
I found this relatively current post in a search, and, I presume, the fuel rail pressure in a 1983 HE would also be 36 psi with engine off (no vacuum) and fuel pump running - correct?
Jerry
Actually, Google “AJ6 Engineering” and pick the Jagweb result; the column on the left has the topics.
Thank you.
I will check that source out.
With the fuel pump wiring disconnected and 12V to the fuel pump, I get 36 psi engine off and no vacuum.
So I go in another direction - starts and runs with starting fluid, so I know ignition system and other system are good, but have now tracked it down to the fuel pump not working with key on. My investigation continues.
Assume you reset the inertia/impact switch?
Yes, first thing I checked.
I found that the two wire leads which plug onto the connectors on the battery + cable had come loose, but had not fallen out for me to notice.
I suspect this happened over time, each I replaced the battery, over the years, with my last battery change being the final one which caused them to loose electrical contact.
I plugged the two leads back onto their terminals in that little plastic housing on the battery + cable and the fuel pump now works as it should.
