Two problems,
- Fuel pump pumps up to pressure but then with the ignition on ,the fuel pump clicks about every 1-2 minutes. Can’t see any leaks from the tank to carbs so would this indicate fuel is leaking at one or both carburetor needle valves?
- When driving the car and decelerating , revs do not drop off quickly but drop slowly from about 2500 to 1000 rpm as the car comes to a stop .
Would the two problems above be related ?
Thanks in advance for any information!
Don
