[quote=“Helder_Maiato, post:35, topic:426812, full:true”]
Hello guys, I think I am back to stage 1…after ordering a new relay to replace the faulty one and replacing also the metal connectors on the white and white/green wires (the old connectors broke when I removed the wires from the socket to jumpwire the relay…) the car started and ran great for few days. However, one day the car just didn’t start at all. I thought it was some bad connection (I found that the metal connectors often got loose from the wires in the socket), so I tried to
jumpstart the white with white/green wires bypassing the relay as before, but now I can’t start the engine. I can hear the pumps working in the back, but no start.
[unquote]
If the fuel pump then runs. Helder; the relay/socket has no bearing on a non-start. I assume the engine is cranking (since you also mention the starter relay)?
[quote]
Before all this saga started, whenever I tried to restart the engine while it was hot, it wouldn’t start at first attempt (it always started at first when engine was cold :-)), with no signs of fuel injection, with very similar symptoms as I get now.
[unquote]
‘…no sign of fuel injection’ - do you mean the injectors are not clicking while cranking?
The injectors are triggered by the ign amplifier - white/black wire connected to coil ‘-’. No injector action; no start - have you checked if a spare plug will spark? Are you sure there is no injector action??
Differences between cold and hot starting is a separate symptom - no hot start may imply an ign amp problem, as said.
Connect a test lamp between coil ‘-’ and ground. With ign ‘on’ the lamp should be fully lit - while cranking the lamp should dim and flicker…
[quote]
…diagram of the starter relay.
I found a loose wire while I was working on the pump relay (might have pulled it inadvertently). I put it back in place where I think it was, but I am not 100% sure.
[unquote]
There are no white wires on the starter relay - if the engine cranks there is nothing wrong with the starter relay…
A white wire gives power to the pump via the pump relay - so the white connection at the relay socket is 100% important…
We’re here to add to your knowledge, Helder…
Frank
xj6 85 Sov Europe (UK/NZ)
