Man after my own heart. Mike’s process is ideal imo.
I do the same…
I am very overkill when it comes to coolant and clean gad lines on these cars.
Specks of debris easoly clog float needles, etc.
These cars reward such perfectionism.
I considered swapping the glass bowl over to the one i intend to keep as it was missing, but chose to get a later bosch type as used on the s3.
Always liked the glass bowl concept as i too like to always be on top of things.
I use the exact same glass filter in your photo just before carbs.
I agree. If the tank isn’t leaking, and depending on overall condition, most often one can simply drain the sour gas.
Removing plug at tank base yields a screen, make sure it’s cleaned. Blow all the lines of course…
If you need to repair fuel gauge sending unit, which is most certainly seized or damaged, removing the cover within wheel well for its access creates perfect oppty to do it all…
The filler neck alone is doable too.
Can’t recall tank capacity at moment. 15gal us?
Anyway, options:
it just bothers me not flushing it out a cursory amount to eliminate at the very least bassic corrosion and sediment.
Go to walmart or wherever, get white vinegar. They sell by gallon, about 1.20$ ea.
Or use evaporust…recommended and reusable.
Put the drain plug back in, and accessing hole where gas gauge was or filler cap, i simply use a slightly modified hand held weed/grass hand pump type sprayer. The kind that has wand attachment. Cheap.
i spray and spray the interior of the tank, repeating for a day or so, whenever i think about it then allow sit overnight.Repeat. Close filller cap each time and tape up gauge hole to keep from evaporating too quickly.
Repeat and drain again. Then spray with water, ue ccompressed air to dry and fill w gas to guard from flash rust.
Or just fillthe tank w vinegar. Worth $20 or so.
Then allow sit a couple days or more, drain, fill w gas, drain, done.
Keep filled w gas to protect tanks from ever rusting again.
Vinegar really works well for rust.
Flushed a cooling system w water, no rust left the system, one i knew had corrosion.
Filled w vinegar (the 1% solution wil not hurt aluminum) let it sit a weekend or so…
Holy smokes. drained and orange gunk water poured out.
now i have an orange driveway i haven’t been able to clean despite several products and scrubbing! Need to go muratic acid route or sand blast…damn iron oxide.
Anyway, that’s what i do.
