I have a 2015 Jag XF. I cannot use the “auto shut off” when refueling. It immediately clicks off. It appears that the gas tank vent pipe is too small. It cannot expel air as rapidly as the auto fill is fueling the tank. Has anyone else experienced this problem? If so, has anyone found a way to correct the issue? I have found the end of the vent hose in the tire well and the ID of the hose is only 3/32 inch diameter. If I increase the ID, will the emission control system think the gas cap is loose and cause the “check engine” light to come on?
Thank you in advance for your response.
RonW
I haven’t had this issue, but I believe its quite common. The response I’ve heard from most people is to rotate the fuel nozzle a bit.
