1988 XJS.
Every few days, my 7.5 amp fuse blows, rendering no directional indicators and brake lights. I’m suspecting a bad brake light socket, but I see the fuse also is for “gearbox override switch”. What is that?
1988 XJS.
Is it transmission kickdown switch or neutral safety switch or ?
Greg,
Don’t know if they did any changes for the 88MY but my 86 has only two gerabox related switches, kickdown and N safety switch.
Take your pick, but I think that the kickdown has a fused labeled “kickdown switch”.
Aristides
What did you do last…have you changed any light bulbs lately…is a bulb in correctly. …etc…didn’t you have another post telling about mods to your kickdown switch…seems like re engineering may lead to more problems
i had changed all brake bulbs a couple months ago. The left rear bulb was corroded in place, I’m guessing I could have a bad socket there.
I ended up making no mods to the kickdown switch. If the kickdown switch is on this fuse, I have temporarily removed the two leads to test. If that’s not it, then I’ll remove left rear brake bulb and see if that keeps fuse from blowing.
I guess I can remove fuse and see if my neutral safety switch works? Duh.
There’s also a reverse light switch.
I have seen the wrong bulb put in a socket and it shorted out…like when some one puts a single contact bulb in a two contact socket. Or some such nonsense …viceversa. …anyway try removing things to isolate the problematic thing
Yes, that’s what I’m doing.
Assuming kickdown switch first, I’ve disconnected that.
