John Ashcroft wrote:
Sorry, when I picked up the gaskets at dealer, asked about the washer, told
me it was just a copper washer. Got it at the bearing place I got the Viton
o’rings.
What size are these ? Anyone who has replaced o-rings with the viton ones could
you please post the sizes so when I run across a place that has them I can grab
the right ones for the eventual change over. Nothing like having the right
parts needed on hand.
bob…>
----- Original Message -----
To: v12-engine@jag-lovers.org
Sent: Wednesday, May 10, 2000 3:20 AM
Subject: Re: [v12-engine] Fiber Washer on Oil Filter HeadFrom: “Kirbert” palmk@nettally.com
You might wanna consider replacing it – with something different
than the fibre original washer. Maybe you can find a copper washer
that will fit. Or maybe one of those fancy steel washers with the
rubber around the inner edge.From: “John Ashcroft” deerashy@bigpond.com
The plug gasket is a copper washer now.
Do you mean that it’s now a copper washer from the factory? Happen
to have a part number?– Kirbert | Palm’s Postulate:
| If anything is to be accomplished,
| some rules must be broken.
| – Kirby Palm, 1979
