Hi, hoping someone with greater knowledge than me can help.
I am trying to identify the fill/ level plug on the manual gearbox on my XJ6 S2.
On the right hand side of the gearbox there are 3 tapped plugs that go through to the gearbox: one larger one at the bottom and two above it vertically in line. See photo
If anyone could identify the correct plug that would be really helpful
The gearbox is a 4 speed synchro with an A Type Compact overdrive
I think it’s on the other side, so on the left but the same height Kirbert identified, unless they changed it. Don‘t forget the overdrive too, and welcome to the forums.
The gearbox oil plug is at the lower front left side of the gearbox. There is also an overdrive oil plug located vertically at the rear left end of the OD unit.
A bit more info on the gearbox, not sure if it helps at all
On the gearbox casing there are two numbers - P33202A and DA20594
On the top cover the number engraved is KPN1632
On the chassis plate the gearbox number is 015/16035, but I’m not sure how reliable that is as the engine number is an 8L number but on the chassis plate it is 7L. So probably had a bit of swapping of components in the past.
All I can say for certain is that the filler / level plug is on the RHS of the gearbox!
They are right. The lower hex head is a drain plug. The top 2 are machine bolts, identified by the markings on the top face. The filler plug has no markings, just a smooth flat top surface. The drain plug on the bottom of the casing would also have a magnet set into it to catch any metal in the fluid.
Numbers cast into the parts are typically part nos. P33202A seems to correlate to the Jaguar part no. for the gearbox case (C.33202). Usually the ID nos. are hammered in along the seal faces at the side of the housing or similar - I identified the number on my Spitfire gearbox only after cleaning the gearbox in uninstalled condition.
