Gearbox Guru Sugestiions
Can anyone point me in the direction of a shop that can swap or repair manual gearbox on XKE S1 3.8 or XKE S3 V12?
Many thanks!
Walt
The lack of a travel radius implies you are willing to take the Jag a considerable distance. Since you show your location as Buffalo NY, is it logical to assume you are looking for a resource close by – say, at least in the New England area??
John Esposito.
Quantum Mechanics LTD.
315 Riggs Street, Building A Unit 3
Oxford, Ct. 06478
Phone 203-463-8299
He is excellent.
Hi Craig. Yes, I’m prepared to haul or ship the car to a reputable shop. Of course, closer would be better, but I’m not discouraged by 500 to 1000 miles from my home in Buffalo for the right expertise.
Thanks for the observation; Glad I could clarify.
Thanks Robert. I will reach out to John.
Another option just outside Boston - Don
don@custom-trans.com
Custom Transportation
Wakefield, MA 01880
+1 (781) 246-7444
He did engine and IRS work on my Series III OTS back in '85-'86.
Drop my name
Hi Craig. Had a long conversation with don today after I mentioned your name. Thanks for the referral. He was very helpful. Sent me a couple of pictures of the diorama he created. Cool stuff!
Super!
Can he help you with your transmission issue(s)?
Yes. He is looking into if I need to remove gearbox to access the drive gear to replace.
What gear do you think needs to be replace? There’s not a single gear in the Jaguar 4 speed gearbox that can be replaced without removing the gearbox; no looking into it to confirm that.
If its the Drive Gear on the Main Shaft for the speedo drive, then you have a chance, but all gears inside the gearbox housing, no chance.
Bill
Bill,
See this thread from the same poster:
It seems likely that this is, indeed, the gear Walter is talking about on his S3.
-David
