I know that OE is x2 lower mounting bolts for the generator, but has anyone ever considered x1 long bolt? I had some difficulty in removing the bolt, nut, from the front by the radiator. Seems x1 long bolt through both generator holes would make things much easier?
Try it and report but I think you would need a tube spacer in between to get the clamping force at both ends. Without it you have only the slotted adjustment to hold location. With it you have clamping at both ends of the pivot and also the bolt at the slot bracket.
