Hi all,
I do have a set of parts to switch from auto to manual gearbox. It includes the getrag gearbox with the Bell housinf EAC5311.
My question is on which XJ car can this be used?
As the engine as probably changed, on which manufacture year can this be used?
Thank you to ones who can help me on this topic.
Michel, I think all XKs had the same bolt pattern and the V12 was changed once or so, probably after the SIII went out of production? Pictures are probably sufficient to find out which one it is, 6 or 12. Maybe there are other differences besides the bolt pattern though.
Getrag fits XJ40 or X300 (i.e. AJ6/AJ16 engines, XJ 1986-97 or XJS 6cyl 1984-1996.
If the bell housing is detachable, then the XK engine can support the Getrag gearbox using an XK bell and small adapter ring between the box and XK bell. I have these.0 or
