I have changed the differential from 3:5:4 to 3:0:1.
Increased the size of my tires to 205’s.
Replaced the angle drive and speedo cable.Had the gauge reconditioned.
Given this, there is no way the speedo will be accurate.
I am hoping to find a portable GPS based system using my phone (heads up display preferred) to solve my accuracy problems.
Time, speed, distance is required.
Anybody got a suggestion?
Bob
Kirbert
2
There doesn’t seem to be any shortage of these things:
Just a note, theres no need to respond individually one post can be seen by all, saves typing multiple replies
Also you can add your location by going to settings and add your country flag.
Check the rules of the Rally you are going on. Classic car rally’s usually prohibit modern devices such as GPS or SatNav and insist on period correct Halda meters or similar.
Hi Bob…recalibrating a speedo is routine…iv had 4 converted in the last 6 months…iv also installed a programmable speedo you fit a pulse adaptor to the end of the speedo cable…from the adaptor u wire to the speedo…drive the car at a measured 60mph (follow someone or use phone app)…press a button and its done…you speedo is then calibrated
