Here are the troubleshooting steps I took in the order of operation to solve my crank/no-start issue:
- Battery check
- Power to fuel pump
- Fuel pump wiring connected correctly
- Fuel filter installed correctly
- Hear the fuel pump run with key in position 2
- Check fuel pressure to rail
- Check for gas in the car
- Check for power at injector harness connection
- Check for power at injector harness to injector
- Listen for injector clicks when cranking
- Listen for injector clicks when manually turning throttle
- Checked throttle position sensor (TPS)
- Check for spark when cranking
- Check crankshaft position sensor (CPS)
- Check flywheel position sensor (FPS)
- Check white coax wiring
