Well I have the clear ordered, so I decided to start removing the wiring from the gold car, these pictures are mainly for me, so I know where they go when I put them all into the other car.
These relays are for the drivers side in my car, in the boot, although one of them has a few wires missing from there, I will need to track those little buggers down. pretty sure they will be for something.
These little buggers go in the boot on the passenger side.
I got to remember about all these earth wires, I have seen how some cars react to not enough earth wires. These ones are in the boot, so not much I can stuff up just yet.
Right! All thewiring from the boot is now in the passenger compartment, and this is the front of the cab area the window is the windscreen, and I would say this is the main harness, I figured this will be where I really need them pictures, can’t be stuffing things up all the time.
Some more earth leads, at the top of the dash area. Then time to remove the mounting plate , giving me a little more room to play with.
More earth leads then remove this box, and get ready to remove the mounting plate as well.
May as well make sure I know where this little bugger goes. Then continue to the next step.
Now to get that mounting plate out of the way to see what is hiding behind there. got to be more earth wires for sure.
Well I got rid of the fan on this side and gues what I found, Yep! more earth leads. also found quite a bit more rust as well, making me kind of glad I decided to stop this project here and go back to the green car.
Unplug the wiring for the passenger side front door, I have also been putting masking tape on almost all of the connectors, just so I have a vague idea about where they are suppose to go, I also found a few wires had been cut, not sure why just yet.
Also have to remember about those vaccuum lines and where they came from. That has kept me in mischief for long enough today, and it looks a little bit like rain is coming so I had better pack it all up for today, the front seats are already in the shed out of the weather.
