On my 420G, and other older auto saloons, is a Neutral Safety Switch, with associated relay, that locks out start in gear and activates Reverse Lights.
Eventually yours will stop working, and you will be in a world of hurt, until you read this.
as far as I know, there is no replacement available for the NSS.
(please alert me if this is incorrect)
Luckily, they can be dismantled and (usually) repaired
I have dismantled NSS from various other vehicles and repaired them, they are hundreds of $ new.
wiil edit in pics shortly, and a guide to diagnose & replace relay
- mark the position of bracket relative to switch…its actually better to take the whole bracket out first in this case
- note the wire colors, carefully pry back the tabs and remove the guts
the inside is badly affected by copper oxidisation
clean with a mild solvent and light wire wool,doesnt that look better!
bolt it back, and be glad you marked it before, as you will be able to avoid the FSM procedure of adjusting it
more later folks
