I have searched the archives and come up empty.
How is the dash harness routed through the steering wheel support on a series 2? I am reusing the old harness so it has some memory of where it was. If I have to fight it into position there must be something incorrect… On the left of the steering support I have all the wires for the speedometer, coming out the top I have a grouping that includes a 4 pole connector. Nothing seems to want to exit the right hand opening, Is this correct? Thanks
69 Coupe
Bill, I did my S2 recently also, with all new harnesses. I only have 2 suggestions:
I installed my wiring and THEN installed the steering column brace, moving the harnesses around a little to avoid any stress/unnecessary tension.
Very Important - make sure you have your heater ducting in place. It’s very hard to try and thread the tubing thru the wiring!
Mark
Murrieta, Ca.
Just what I needed Thanks
