Hazard warning lights in the dash without function
hello on my 1990 the indicators in the dash do not work.
the click is audible.
normal Turn indicators in the dash works fine
Thanks
Thanks
Hello Stojan - I do not have a wiring schematic for your XJ40 - but from vague memory, do you have two separate circuits - one for hazard flasher and one for turn signals, that become one common circuit - if so, you would have two different relays - sounds like turn signal relay circuit works, but hazard flasher relay circuit is open - possibly dirty contacts since you said you hear relay click - what year is your XJ40?
