not sure if head gasket BJ020 is steel or copper makes a difference to torque setting this is for 68 E Type 4.2 gasket is in place any help thanks
No it doesn’t.
20 characters
Should the cylinder head studs/bolts be torqued on a cold or hot engine and at what reading?
Charlie
Cold, and I believe it depends on the engine.
Then re-torqued cold after the first heat cycle and then again after maybe 100 miles.
